Codice Raw Mariani CLima LG
MessaggioInviato:09/07/2019, 16:17
Comando ON
Encoding : LG
Code : 880094D (28 bits)
uint16_t rawData[59] = {8486, 4210, 544, 1568, 542, 514, 514, 542, 514, 542, 512, 1600, 542, 514, 542, 514, 542, 512, 542, 514, 514, 542, 542, 512, 540, 516, 542, 512, 516, 540, 540, 516, 542, 514, 512, 1600, 540, 516, 518, 538, 514, 1598, 542, 512, 514, 1598, 542, 514, 542, 514, 512, 1600, 512, 1598, 542, 514, 540, 1572, 542}; // LG 880094D
uint32_t address = 0x88;
uint32_t command = 0x94;
uint64_t data = 0x880094D;
Comando Selezione modalità
Encoding : LG
Code : 8809B04 (28 bits)
uint16_t rawData[59] = {8458, 4238, 516, 1598, 526, 530, 522, 534, 520, 536, 520, 1590, 526, 530, 520, 534, 522, 534, 522, 534, 526, 530, 516, 540, 522, 534, 520, 1592, 526, 530, 522, 534, 522, 1590, 516, 1596, 514, 540, 520, 1594, 516, 1596, 512, 542, 512, 542, 518, 536, 518, 536, 522, 534, 524, 1588, 524, 530, 516, 540, 520}; // LG 8809B04
uint32_t command = 0x9B0;
uint64_t data = 0x8809B04;
Comando Aumento Temperatura
Encoding : LG
Code : 8809C05 (28 bits)
uint16_t rawData[59] = {8488, 4206, 524, 1590, 546, 508, 516, 542, 484, 570, 486, 1626, 514, 542, 514, 540, 488, 568, 522, 534, 486, 568, 520, 536, 486, 570, 524, 1588, 548, 508, 548, 508, 548, 1564, 544, 1568, 548, 1564, 548, 508, 522, 534, 546, 508, 518, 538, 546, 510, 484, 570, 546, 508, 486, 1626, 516, 540, 484, 1626, 548}; // LG 8809C05
uint32_t command = 0x9C0;
uint64_t data = 0x8809C05;
Comando Diminuire Temperatura
Encoding : LG
uint16_t rawData[59] = {8458, 4220, 532, 1580, 532, 540, 514, 526, 532, 522, 532, 1580, 532, 540, 516, 540, 516, 540, 514, 540, 516, 540, 516, 540, 514, 540, 516, 1580, 532, 526, 530, 540, 514, 1580, 532, 1580, 532, 524, 530, 1580, 532, 1596, 516, 526, 530, 540, 514, 526, 530, 540, 516, 540, 514, 1598, 514, 540, 516, 524, 530}; // LG 8809B04
Comando Velocità Ventola
Encoding : LG
Code : 8809B26 (28 bits)
uint16_t rawData[59] = {8410, 4288, 498, 1614, 464, 592, 496, 558, 466, 590, 498, 1614, 464, 590, 494, 562, 464, 590, 496, 560, 494, 562, 488, 568, 466, 590, 466, 1646, 488, 568, 464, 592, 464, 1648, 464, 1646, 496, 562, 464, 1646, 496, 1616, 488, 568, 494, 562, 466, 1646, 496, 560, 486, 568, 500, 1614, 488, 1622, 486, 568, 496}; // LG 8809B26
uint32_t command = 0x9B2;
uint64_t data = 0x8809B26;
Comando Movimento Flaps
Encoding : LG
Code : 8810001 (28 bits)
uint16_t rawData[59] = {8492, 4188, 508, 1622, 548, 508, 548, 508, 548, 508, 546, 1566, 546, 508, 546, 510, 572, 482, 548, 510, 570, 486, 570, 486, 544, 1566, 546, 510, 544, 512, 544, 512, 542, 514, 540, 516, 538, 516, 538, 518, 490, 566, 538, 518, 488, 566, 490, 566, 488, 566, 490, 566, 488, 566, 490, 566, 490, 1622, 490}; // LG 8810001
uint32_t command = 0x1000;
uint64_t data = 0x8810001;
Encoding : LG
Encoding : LG
Encoding : LG
Encoding : LG
Encoding : LG
Encoding : LG
