 #3896  da ol6iolxg
 05/06/2021, 8:03
This version of adidas Ultra Boost ATR Mid Primeknit is done in a clean Grey Primeknit construction. The nmdsize.com same hue is used for the heel cage, laces and the sock collar. If you take a close look at the Three Stripes branding you will see that they appear to be embossed on to the Primeknit. Below you will find a full-length Boost midsole done in White to complete the look.
The Adidas Sneakers Women White simply inspired by its original Ultra Boost model and this version features a mixture of tan with specks of grey and black covering the full Primeknit upper. More black trimming is seen on the sock-like collar, and completing the sleek design is a tan heel counter, white Boost midsole and black rubber outsole.
This Adidas Ultra Boost ATR Undye Pack Triple White features a water-repellent Primeknit upper to keep your feet dry, while having an extended collar to give you more advantage against the elements. A molded heel, midfoot cage, full-length Boost midsole and rugged outsole for all-weather traction completes the design.
Ahead of its anticipated spring launch, the Top Quality Adidas Ultra Boost ATR Mid surfaces in a second "Oreo" colorway. More white is worked into the Primeknit upper of this pair, including the tongue and collar. Another distinctive feature is the use of a black Boost midsole, which rides atop a white Continental rubber outsole.
https://www.nmdsize.com/
