  • Codici Raw Pinguino De’ Longhi (PAC N87 Silent)
  • Postate in questa sezione i codici RAW dei vostri telecomandi. Nel titolo inserite solo la marca
 #689  da fumiplettro
 08/07/2019, 16:06
Ecco a voi finalmente i codici raw del climatizzatore Pinguino De’Longhi PAC N87 Silent:
COMANDO ON (TEMP 16° E VENTOLA AL MINIMO)
Encoding : NEC (non-strict)
Code : 124821B0 (32 bits)
uint16_t rawData[67] = {9092, 4426, 604, 502, 572, 534, 582, 498, 606, 1606, 582, 496, 608, 498, 606, 1606, 582, 498, 608, 498, 574, 1610, 610, 496, 598, 508, 576, 1610, 598, 508, 576, 502, 602, 504, 600, 506, 576, 528, 576, 1610, 578, 528, 578, 502, 602, 504, 600, 506, 578, 1606, 602, 1610, 578, 502, 604, 1608, 580, 1606, 604, 502, 580, 498, 606, 500, 604, 528, 556}; // NEC (non-strict) 124821B0
uint32_t address = 0x1248;
uint32_t command = 0x0;
uint64_t data = 0x124821B0;
COMANDO OFF
Code : 124880B0 (32 bits)
uint16_t rawData[67] = {9092, 4426, 604, 500, 604, 502, 582, 498, 606, 1606, 582, 524, 582, 498, 606, 1606, 582, 496, 608, 498, 596, 1590, 610, 496, 598, 508, 574, 1612, 598, 508, 576, 530, 574, 506, 598, 1612, 576, 504, 602, 504, 598, 506, 578, 502, 602, 504, 600, 506, 578, 530, 576, 1610, 578, 526, 578, 1608, 602, 1584, 604, 502, 602, 504, 580, 500, 606, 500, 604}; // NEC (non-strict) 124880B0
uint64_t data = 0x124880B0;
FUNZIONE CONDIZIONATORE
16° VENTOLA A 1
Code : 12482100 (32 bits)
uint16_t rawData[67] = {9088, 4428, 602, 504, 600, 504, 578, 528, 576, 1610, 580, 526, 632, 448, 602, 1610, 580, 526, 578, 500, 604, 1608, 580, 500, 604, 500, 572, 1612, 608, 498, 606, 500, 584, 522, 582, 498, 606, 500, 574, 1612, 610, 496, 576, 530, 574, 506, 600, 506, 598, 1614, 576, 504, 600, 506, 578, 528, 576, 502, 654, 452, 578, 528, 576, 502, 602, 504, 600}; // NEC (non-strict) 12482100
uint64_t data = 0x12482100;
16° VENTOLA A 2
Code : 12282100 (32 bits)
uint16_t rawData[67] = {9120, 4426, 604, 474, 630, 476, 628, 478, 606, 1580, 630, 476, 576, 530, 606, 1580, 630, 476, 606, 472, 632, 474, 630, 1554, 634, 472, 632, 1580, 576, 504, 632, 474, 620, 484, 578, 502, 602, 502, 632, 1554, 604, 502, 634, 472, 578, 500, 604, 502, 634, 1580, 578, 502, 604, 502, 624, 482, 580, 500, 604, 502, 624, 482, 580, 500, 604, 502, 634}; // NEC (non-strict) 12282100
uint32_t address = 0x1448;
uint64_t data = 0x12282100;
16° VENTOLA A 3
Code : 12182100 (32 bits)
uint16_t rawData[67] = {9094, 4452, 578, 500, 604, 502, 602, 504, 580, 1606, 604, 502, 580, 498, 606, 1608, 570, 534, 580, 498, 606, 500, 604, 502, 582, 1604, 604, 1580, 608, 498, 606, 500, 574, 532, 572, 506, 608, 498, 576, 1610, 608, 498, 598, 508, 574, 506, 600, 506, 598, 1588, 600, 506, 600, 506, 576, 530, 576, 504, 600, 506, 578, 502, 602, 504, 602, 504, 600}; // NEC (non-strict) 12182100
uint32_t address = 0x1848;
uint64_t data = 0x12182100;
17° VENTOLA A 1
Code : 12482180 (32 bits)
uint16_t rawData[67] = {9090, 4430, 602, 504, 600, 506, 598, 508, 574, 1610, 600, 506, 576, 528, 576, 1610, 598, 508, 576, 502, 602, 1610, 578, 502, 602, 504, 600, 1612, 576, 502, 602, 504, 578, 528, 576, 502, 602, 504, 600, 1586, 604, 502, 602, 504, 578, 500, 604, 502, 602, 1610, 578, 1608, 580, 526, 578, 500, 602, 504, 602, 504, 578, 500, 604, 502, 602, 502, 580}; // NEC (non-strict) 12482180
uint64_t data = 0x12482180;
17° VENTOLA A 2
Code : 12282180 (32 bits)
uint16_t rawData[67] = {9090, 4456, 574, 532, 582, 522, 550, 530, 576, 1610, 598, 534, 548, 530, 574, 1610, 578, 528, 576, 504, 602, 530, 552, 1606, 602, 504, 602, 1610, 578, 502, 602, 530, 552, 526, 578, 502, 602, 504, 580, 1606, 604, 502, 602, 502, 580, 552, 552, 500, 604, 1608, 580, 1606, 572, 534, 582, 524, 580, 500, 604, 500, 584, 522, 582, 498, 606, 500, 574}; // NEC (non-strict) 12282180
uint64_t data = 0x12282180;
17° VENTOLA A 3
Code : 12182180 (32 bits)
uint16_t rawData[67] = {9090, 4430, 602, 504, 632, 474, 576, 502, 602, 1610, 630, 448, 604, 502, 600, 1610, 578, 500, 604, 502, 634, 472, 580, 500, 604, 1608, 582, 1604, 604, 502, 622, 482, 580, 500, 604, 500, 624, 482, 582, 1604, 626, 480, 582, 498, 606, 500, 604, 500, 624, 1562, 606, 1606, 572, 506, 608, 498, 596, 510, 574, 506, 608, 498, 598, 508, 574, 506, 600}; // NEC (non-strict) 12182180
uint64_t data = 0x12182180;
18° VENTOLA A 1
Code : 12482140 (32 bits)
uint16_t rawData[67] = {9092, 4430, 600, 504, 578, 528, 576, 502, 602, 1610, 578, 502, 602, 504, 600, 1586, 604, 502, 602, 504, 578, 1608, 602, 504, 580, 526, 578, 1608, 622, 484, 580, 500, 604, 502, 602, 504, 580, 500, 604, 1608, 582, 498, 604, 500, 604, 502, 570, 510, 606, 1606, 624, 482, 580, 1606, 604, 502, 582, 498, 606, 500, 604, 502, 582, 498, 606, 500, 606}; // NEC (non-strict) 12482140
uint64_t data = 0x12482140;
18° VENTOLA A 2
Code : 12282140 (32 bits)
uint16_t rawData[67] = {9090, 4456, 574, 506, 600, 506, 598, 508, 576, 1610, 600, 506, 576, 528, 576, 1610, 578, 528, 578, 502, 602, 504, 600, 1586, 602, 504, 602, 1610, 576, 502, 602, 504, 580, 526, 578, 502, 602, 504, 580, 1606, 604, 502, 602, 504, 580, 500, 656, 450, 602, 1610, 578, 500, 604, 1610, 580, 500, 604, 502, 602, 504, 580, 500, 604, 502, 602, 502, 580}; // NEC (non-strict) 12282140
uint64_t data = 0x12282140;
18* VENTOLA A 3
Code : 12182140 (32 bits)
uint16_t rawData[67] = {9090, 4456, 574, 506, 600, 506, 598, 508, 574, 1612, 598, 508, 576, 504, 600, 1612, 576, 530, 628, 452, 600, 506, 576, 530, 574, 1612, 578, 1608, 600, 506, 600, 506, 576, 504, 600, 504, 600, 506, 576, 1610, 600, 506, 578, 528, 576, 502, 600, 506, 600, 1586, 602, 506, 598, 1586, 602, 504, 600, 506, 578, 502, 604, 502, 600, 506, 578, 502, 602}; // NEC (non-strict) 12182140
uint64_t data = 0x12182140;
19° VENTOLA A 1
Code : 124821C0 (32 bits)
uint16_t rawData[67] = {9090, 4430, 602, 504, 662, 444, 576, 502, 602, 1612, 576, 528, 576, 504, 600, 1612, 578, 502, 602, 504, 600, 1612, 574, 504, 600, 506, 578, 1608, 600, 506, 578, 528, 628, 452, 654, 452, 598, 506, 630, 1558, 600, 506, 578, 502, 602, 504, 600, 506, 578, 1608, 600, 1612, 576, 1610, 600, 506, 576, 502, 602, 504, 600, 506, 578, 502, 602, 504, 602}; // NEC (non-strict) 124821C0
uint64_t data = 0x124821C0;
19° VENTOLA A 2
Code : 122821C0 (32 bits)
uint16_t rawData[67] = {9094, 4426, 604, 502, 582, 524, 580, 498, 606, 1606, 582, 550, 554, 526, 578, 1608, 582, 498, 606, 498, 574, 558, 556, 1602, 576, 532, 572, 1612, 608, 498, 574, 504, 600, 506, 608, 498, 576, 558, 546, 1612, 576, 556, 548, 504, 602, 504, 598, 508, 576, 1610, 600, 1612, 576, 1610, 578, 554, 550, 502, 602, 504, 580, 526, 578, 502, 602, 504, 600}; // NEC (non-strict) 122821C0
uint64_t data = 0x122821C0;
19° VENTOLA A 3
Code : 121821C0 (32 bits)
uint16_t rawData[67] = {9088, 4428, 602, 532, 552, 554, 550, 528, 576, 1608, 580, 554, 550, 530, 576, 1608, 580, 528, 576, 530, 554, 552, 554, 526, 578, 1606, 582, 1604, 606, 528, 556, 550, 554, 524, 580, 526, 546, 560, 554, 1602, 576, 558, 546, 532, 582, 524, 570, 536, 548, 1610, 610, 1602, 576, 1610, 578, 556, 548, 530, 574, 532, 572, 534, 550, 530, 574, 532, 574}; // NEC (non-strict) 121821C0
uint64_t data = 0x121821C0;
20° VENTOLA A 1
Code : 12482120 (32 bits)
uint16_t rawData[67] = {9088, 4458, 604, 476, 628, 478, 628, 478, 572, 1614, 660, 446, 606, 474, 598, 1614, 574, 532, 572, 506, 630, 1584, 574, 506, 598, 508, 628, 1556, 600, 506, 630, 478, 574, 530, 574, 506, 630, 476, 576, 1610, 600, 508, 628, 476, 574, 506, 630, 474, 630, 1556, 602, 504, 630, 476, 576, 1610, 630, 474, 576, 530, 576, 504, 600, 506, 630, 448, 604}; // NEC (non-strict) 12482120
uint64_t data = 0x12482120;
20° VENTOLA A 2
Code : 12282120 (32 bits)
uint16_t rawData[67] = {9100, 4448, 582, 522, 582, 526, 546, 534, 582, 1604, 606, 528, 556, 522, 582, 1604, 574, 558, 556, 524, 580, 526, 546, 1612, 608, 526, 548, 1612, 608, 524, 580, 526, 546, 532, 582, 524, 580, 526, 546, 1612, 608, 526, 548, 532, 582, 522, 582, 524, 548, 1610, 610, 524, 548, 558, 548, 1612, 608, 498, 574, 532, 584, 522, 582, 498, 574, 532, 582}; // NEC (non-strict) 12282120
uint64_t data = 0x12282120;
20° VENTOLA A 3
Code : 12182120 (32 bits)
uint16_t rawData[67] = {9098, 4420, 610, 496, 576, 528, 576, 504, 600, 1612, 576, 530, 574, 504, 600, 1612, 576, 504, 600, 506, 578, 554, 550, 504, 602, 1610, 578, 1610, 600, 504, 578, 554, 550, 502, 602, 532, 552, 526, 578, 1608, 580, 552, 552, 500, 604, 502, 582, 524, 578, 1608, 602, 504, 580, 526, 578, 1606, 582, 524, 580, 500, 606, 500, 582, 550, 554, 526, 580}; // NEC (non-strict) 12182120
uint64_t data = 0x12182120;
21° VENTOLA A 1
Code : 124821A0 (32 bits)
uint16_t rawData[67] = {9118, 4430, 578, 502, 604, 502, 570, 536, 600, 1586, 572, 534, 602, 504, 580, 1608, 600, 506, 600, 480, 604, 1608, 580, 500, 606, 502, 602, 1584, 604, 500, 572, 534, 602, 476, 606, 500, 604, 502, 570, 1616, 604, 502, 604, 504, 600, 480, 624, 480, 572, 1614, 606, 1608, 602, 478, 604, 1608, 602, 478, 626, 480, 626, 480, 572, 508, 606, 500, 594}; // NEC (non-strict) 124821A0
uint64_t data = 0x124821A0;
21° VENTOLA A 2
Code : 122821A0 (32 bits)
uint16_t rawData[67] = {9092, 4456, 576, 530, 574, 532, 550, 556, 548, 1610, 578, 528, 576, 530, 574, 1612, 578, 528, 576, 530, 574, 532, 550, 1608, 602, 532, 550, 1608, 600, 532, 552, 554, 550, 528, 576, 530, 574, 532, 552, 1608, 602, 532, 552, 554, 550, 528, 576, 530, 554, 1606, 604, 1608, 580, 528, 578, 1608, 580, 552, 552, 528, 576, 530, 554, 526, 578, 528, 578}; // NEC (non-strict) 122821A0
uint64_t data = 0x122821A0;
21° VENTOLA A 3
Code : 121821A0 (32 bits)
uint16_t rawData[67] = {9094, 4454, 576, 530, 574, 532, 552, 554, 550, 1608, 580, 554, 550, 530, 576, 1610, 578, 530, 576, 530, 574, 532, 552, 528, 576, 1608, 580, 1606, 604, 530, 552, 554, 552, 528, 576, 530, 552, 554, 552, 1606, 602, 532, 552, 526, 578, 528, 576, 530, 554, 1604, 604, 1608, 580, 528, 576, 1608, 580, 526, 578, 528, 556, 552, 552, 528, 578, 528, 576}; // NEC (non-strict) 121821A0
uint64_t data = 0x121821A0;
22° VENTOLA A 1
Code : 12482160 (32 bits)
uint16_t rawData[67] = {9090, 4430, 630, 476, 630, 476, 628, 478, 606, 1580, 630, 478, 606, 474, 632, 1580, 576, 530, 606, 474, 630, 1582, 608, 472, 632, 474, 630, 1556, 632, 474, 632, 474, 610, 470, 634, 472, 632, 474, 578, 1608, 634, 472, 578, 500, 636, 470, 634, 472, 622, 1564, 634, 472, 632, 1554, 634, 1576, 580, 526, 610, 470, 634, 472, 580, 526, 610, 470, 636}; // NEC (non-strict) 12482160
uint64_t data = 0x12482160;
22° VENTOLA A 2
Code : 12282160 (32 bits)
uint16_t rawData[67] = {9096, 4452, 578, 500, 604, 502, 580, 526, 578, 1608, 602, 504, 580, 526, 578, 1608, 580, 526, 578, 500, 604, 502, 580, 1606, 604, 502, 582, 1604, 604, 502, 604, 502, 580, 526, 578, 502, 604, 502, 580, 1606, 604, 502, 582, 524, 580, 500, 604, 502, 582, 1604, 606, 502, 582, 1604, 606, 1606, 582, 524, 580, 500, 604, 502, 582, 498, 606, 500, 604}; // NEC (non-strict) 12282160
uint64_t data = 0x12282160;
22° VENTOLA A 3
Code : 12182160 (32 bits)
uint16_t rawData[67] = {9096, 4452, 578, 500, 604, 502, 602, 506, 578, 1608, 602, 504, 578, 502, 602, 1610, 578, 528, 578, 502, 602, 504, 578, 526, 578, 1608, 580, 1606, 602, 504, 600, 506, 578, 500, 604, 502, 602, 504, 578, 1608, 602, 504, 580, 500, 604, 504, 600, 504, 578, 1608, 602, 504, 580, 1608, 602, 1610, 578, 502, 604, 502, 602, 504, 578, 500, 604, 504, 600}; // NEC (non-strict) 12182160
uint64_t data = 0x12182160;
23° VENTOLA A 1
Code : 124821E0 (32 bits)
uint16_t rawData[67] = {9092, 4430, 602, 504, 600, 506, 630, 474, 576, 1610, 600, 506, 578, 502, 602, 1610, 578, 528, 576, 504, 600, 1612, 578, 502, 602, 504, 600, 1586, 602, 504, 600, 506, 578, 500, 604, 502, 602, 504, 578, 1608, 602, 502, 580, 526, 578, 502, 604, 502, 580, 1606, 604, 1608, 580, 1606, 604, 1610, 578, 500, 604, 502, 572, 508, 608, 498, 606, 502, 572}; // NEC (non-strict) 124821E0
uint64_t data = 0x124821E0;
23° VENTOLA A 2
Code : 122821E0 (32 bits)
uint16_t rawData[67] = {9092, 4454, 576, 504, 632, 474, 600, 506, 576, 1608, 600, 506, 600, 480, 634, 1606, 624, 482, 602, 502, 580, 500, 594, 1618, 604, 476, 626, 1586, 572, 508, 596, 510, 572, 532, 604, 502, 570, 508, 574, 1638, 602, 476, 596, 510, 606, 500, 572, 508, 598, 1616, 604, 1582, 576, 1636, 606, 1580, 608, 472, 632, 474, 598, 506, 576, 530, 574, 506, 630}; // NEC (non-strict) 122821E0
uint64_t data = 0x122821E0;
23° VENTOLA A 3
Code : 121821E0 (32 bits)
uint16_t rawData[67] = {9098, 4422, 608, 524, 580, 524, 548, 558, 556, 1602, 576, 532, 574, 532, 582, 1602, 574, 532, 582, 524, 550, 556, 548, 532, 572, 1612, 576, 1610, 600, 534, 550, 556, 548, 532, 572, 532, 550, 530, 574, 1610, 580, 554, 550, 530, 574, 532, 552, 554, 550, 1608, 600, 1612, 576, 1610, 580, 1606, 602, 532, 552, 554, 550, 528, 576, 532, 552, 554, 550}; // NEC (non-strict) 121821E0
uint64_t data = 0x121821E0;
24° VENTOLA A 1
Code : 12482110 (32 bits)
uint16_t rawData[67] = {9094, 4452, 578, 500, 604, 504, 600, 504, 578, 1608, 602, 504, 580, 526, 576, 1608, 580, 526, 578, 502, 602, 1610, 578, 502, 604, 502, 602, 1584, 604, 504, 600, 504, 580, 500, 604, 502, 602, 504, 578, 1608, 602, 504, 580, 500, 604, 502, 602, 504, 578, 1608, 602, 504, 600, 506, 578, 502, 602, 1610, 578, 502, 604, 502, 602, 506, 578, 502, 604}; // NEC (non-strict) 12482110
uint64_t data = 0x12482110;
24° VENTOLA A 2
Code : 12282110 (32 bits)
uint16_t rawData[67] = {9098, 4422, 608, 498, 606, 500, 584, 522, 582, 1604, 574, 532, 582, 498, 606, 1606, 582, 524, 582, 498, 606, 500, 574, 1612, 608, 526, 546, 1612, 608, 498, 574, 532, 584, 496, 608, 498, 574, 532, 572, 1612, 608, 498, 574, 506, 610, 524, 580, 498, 574, 1612, 608, 498, 576, 504, 610, 496, 608, 1604, 574, 532, 582, 498, 576, 558, 546, 506, 610}; // NEC (non-strict) 12282110
uint64_t data = 0x12282110;
24° VENTOLA A 3
Code : 12182110 (32 bits)
uint16_t rawData[67] = {9092, 4452, 632, 448, 634, 472, 580, 526, 600, 1586, 602, 504, 580, 500, 636, 1576, 580, 526, 578, 502, 604, 502, 580, 526, 600, 1586, 570, 1616, 636, 470, 622, 484, 600, 478, 604, 502, 656, 450, 602, 1586, 624, 482, 580, 500, 604, 502, 624, 482, 580, 1606, 604, 502, 570, 538, 598, 480, 636, 1578, 580, 526, 598, 480, 602, 504, 600, 506, 576}; // NEC (non-strict) 12182110
uint64_t data = 0x12182110;
25° VENTOLA A 1
Code : 12482190 (32 bits)
uint16_t rawData[67] = {9092, 4430, 600, 506, 598, 506, 578, 528, 576, 1610, 578, 528, 576, 504, 600, 1612, 576, 504, 602, 504, 600, 1586, 602, 504, 600, 506, 578, 1608, 600, 506, 578, 500, 604, 502, 602, 504, 580, 526, 578, 1610, 578, 526, 578, 502, 602, 504, 600, 506, 578, 1608, 600, 1586, 602, 504, 600, 506, 578, 1608, 600, 506, 578, 528, 576, 504, 654, 452, 578}; // NEC (non-strict) 12482190
uint64_t data = 0x12482190;
25° VENTOLA A 2
Code : 12282190 (32 bits)
uint16_t rawData[67] = {9100, 4422, 608, 526, 580, 500, 582, 524, 580, 1606, 582, 524, 582, 524, 580, 1606, 584, 524, 580, 498, 574, 532, 584, 1602, 608, 500, 574, 1612, 608, 498, 574, 558, 556, 496, 608, 498, 574, 558, 556, 1602, 576, 558, 556, 522, 582, 498, 574, 532, 574, 1610, 598, 1588, 612, 522, 582, 498, 574, 1610, 610, 524, 548, 532, 572, 532, 582, 498, 576}; // NEC (non-strict) 12282190
uint64_t data = 0x12282190;
25° VENTOLA A 3
Code : 12182190 (32 bits)
uint16_t rawData[67] = {9122, 4400, 630, 474, 628, 478, 574, 506, 630, 1582, 576, 530, 606, 474, 630, 1582, 606, 474, 630, 476, 628, 478, 606, 474, 632, 1582, 576, 1610, 632, 474, 576, 504, 632, 474, 630, 476, 630, 476, 606, 1580, 630, 476, 608, 472, 600, 506, 630, 476, 608, 1578, 632, 1582, 606, 472, 632, 474, 620, 1566, 632, 474, 630, 476, 608, 472, 632, 474, 630}; // NEC (non-strict) 12182190
uint64_t data = 0x12182190;
26° VENTOLA A 1
Code : 12482150 (32 bits)
uint16_t rawData[67] = {9094, 4428, 602, 504, 600, 506, 578, 502, 604, 1610, 578, 528, 576, 504, 600, 1610, 578, 502, 602, 504, 632, 1554, 602, 504, 600, 506, 578, 1608, 600, 506, 578, 502, 602, 504, 600, 506, 578, 502, 600, 1612, 630, 450, 602, 504, 600, 506, 630, 476, 574, 1612, 598, 508, 576, 1610, 598, 508, 576, 1612, 598, 508, 576, 504, 600, 506, 598, 508, 576}; // NEC (non-strict) 12482150
uint64_t data = 0x12482150;
26° VENTOLA A 2
Code : 12282150 (32 bits)
uint16_t rawData[67] = {9100, 4422, 608, 526, 578, 500, 582, 524, 582, 1604, 574, 560, 556, 524, 580, 1606, 584, 524, 580, 526, 548, 532, 582, 1602, 606, 526, 556, 1602, 608, 500, 574, 558, 556, 524, 580, 500, 572, 560, 556, 1604, 574, 558, 558, 522, 580, 498, 574, 532, 584, 1602, 608, 500, 574, 1612, 608, 498, 574, 1612, 608, 498, 574, 532, 584, 496, 608, 498, 574}; // NEC (non-strict) 12282150
uint64_t data = 0x12282150;
26° VENTOLA A 3
Code : 12182150 (32 bits)
uint16_t rawData[67] = {9096, 4450, 578, 528, 578, 530, 554, 550, 552, 1606, 604, 530, 552, 526, 578, 1606, 582, 552, 552, 528, 576, 530, 554, 524, 580, 1604, 584, 1602, 608, 526, 546, 560, 554, 524, 580, 526, 578, 502, 582, 1604, 606, 528, 556, 550, 554, 526, 578, 500, 582, 1602, 608, 526, 556, 1602, 606, 526, 578, 1582, 608, 526, 578, 500, 582, 550, 554, 526, 578}; // NEC (non-strict) 12182150
uint64_t data = 0x12182150;
27° VENTOLA A 1
Code : 124821D0 (32 bits)
uint16_t rawData[67] = {9098, 4424, 606, 526, 578, 528, 554, 524, 580, 1606, 582, 524, 580, 526, 578, 1608, 580, 526, 578, 528, 556, 1604, 606, 526, 546, 534, 580, 1604, 604, 528, 556, 524, 580, 526, 576, 528, 554, 526, 578, 1608, 580, 526, 578, 528, 576, 530, 554, 526, 578, 1608, 582, 1604, 604, 1608, 580, 526, 578, 1608, 580, 526, 578, 502, 602, 530, 554, 526, 578}; // NEC (non-strict) 124821D0
uint64_t data = 0x124821D0;
27° VENTOLA A 2
Code : 122821D0 (32 bits)
uint16_t rawData[67] = {9096, 4426, 604, 502, 602, 504, 580, 500, 604, 1610, 580, 526, 578, 502, 602, 1610, 578, 502, 604, 502, 580, 526, 578, 1608, 602, 504, 580, 1608, 602, 502, 580, 500, 604, 502, 602, 504, 580, 526, 578, 1608, 570, 536, 578, 500, 604, 502, 570, 536, 580, 1608, 602, 1584, 604, 1608, 580, 500, 604, 1608, 570, 536, 580, 500, 604, 502, 570, 536, 580}; // NEC (non-strict) 122821D0
uint64_t data = 0x122821D0;
27° VENTOLA A 3
Code : 121821D0 (32 bits)
uint16_t rawData[67] = {9092, 4428, 602, 504, 580, 526, 578, 502, 604, 1608, 580, 500, 604, 502, 570, 1616, 604, 502, 602, 504, 580, 500, 604, 502, 602, 1582, 606, 1606, 582, 524, 580, 500, 606, 500, 572, 508, 608, 498, 606, 1608, 580, 498, 606, 500, 606, 500, 582, 498, 660, 1554, 572, 1614, 606, 1606, 582, 496, 608, 1604, 574, 508, 606, 498, 596, 510, 636, 444, 608}; // NEC (non-strict) 121821D0
uint64_t data = 0x121821D0;
28° VENTOLA A 1
Code : 12482130 (32 bits)
uint16_t rawData[67] = {9092, 4428, 602, 504, 600, 506, 600, 506, 578, 1608, 600, 506, 578, 502, 602, 1612, 578, 528, 578, 502, 600, 1612, 576, 502, 602, 504, 578, 1608, 602, 504, 600, 506, 578, 502, 602, 504, 600, 506, 578, 1608, 602, 504, 578, 528, 578, 502, 602, 504, 578, 1608, 602, 504, 602, 504, 578, 1608, 602, 1584, 604, 502, 602, 504, 578, 528, 578, 502, 602}; // NEC (non-strict) 12482130
uint64_t data = 0x12482130;
28° VENTOLA A 2
Code : 12282130 (32 bits)
uint16_t rawData[67] = {9100, 4422, 608, 498, 606, 500, 584, 522, 582, 1604, 574, 532, 582, 498, 608, 1606, 582, 496, 608, 498, 574, 532, 584, 1604, 606, 500, 572, 1612, 608, 526, 548, 532, 582, 498, 608, 498, 574, 532, 582, 1602, 574, 532, 574, 506, 608, 498, 574, 532, 572, 1614, 608, 498, 574, 504, 610, 1604, 574, 1612, 608, 498, 574, 530, 574, 506, 608, 498, 576}; // NEC (non-strict) 12282130
uint64_t data = 0x12282130;
28° VENTOLA A 3
Code : 12182130 (32 bits)
uint16_t rawData[67] = {9094, 4428, 602, 504, 632, 474, 578, 530, 574, 1610, 620, 486, 576, 504, 600, 1612, 576, 504, 602, 504, 632, 476, 576, 502, 600, 1612, 578, 1608, 632, 474, 578, 528, 576, 504, 632, 474, 630, 450, 602, 1610, 630, 476, 576, 504, 600, 506, 630, 476, 576, 1610, 630, 476, 576, 502, 602, 1612, 576, 1610, 600, 506, 630, 476, 576, 504, 600, 506, 630}; // NEC (non-strict) 12182130
uint64_t data = 0x12182130;
29° VENTOLA A 1
uint16_t rawData[67] = {9100, 4422, 608, 526, 580, 500, 604, 528, 556, 1602, 608, 526, 556, 550, 554, 1604, 574, 560, 556, 524, 580, 1604, 584, 522, 582, 498, 576, 1610, 610, 524, 582, 498, 574, 532, 582, 524, 582, 498, 574, 1610, 610, 524, 550, 556, 556, 522, 582, 498, 574, 1610, 610, 1602, 576, 558, 556, 1602, 576, 1610, 610, 524, 550, 556, 548, 532, 582, 498, 576}; // NEC (non-strict) 124821B0
29° VENTOLA A 2
Code : 122821B0 (32 bits)
uint16_t rawData[67] = {9088, 4458, 582, 498, 608, 498, 574, 532, 584, 1604, 606, 500, 572, 506, 608, 1604, 574, 506, 608, 498, 608, 498, 574, 1612, 608, 498, 574, 1612, 608, 498, 576, 530, 574, 506, 608, 498, 596, 510, 636, 1550, 606, 498, 574, 506, 608, 498, 608, 498, 574, 1612, 608, 1606, 584, 496, 608, 1604, 574, 1612, 596, 510, 574, 506, 610, 496, 596, 510, 574}; // NEC (non-strict) 122821B0
uint64_t data = 0x122821B0;
29° VENTOLA A 3
Code : 121821B0 (32 bits)
uint16_t rawData[67] = {9100, 4422, 608, 498, 606, 500, 574, 532, 582, 1604, 574, 504, 610, 496, 608, 1606, 572, 506, 608, 498, 596, 510, 574, 506, 608, 1604, 574, 1612, 608, 498, 574, 506, 608, 498, 608, 498, 574, 506, 608, 1604, 606, 500, 582, 496, 608, 498, 606, 500, 584, 1602, 606, 1580, 608, 498, 606, 1606, 582, 1604, 574, 532, 582, 496, 608, 500, 574, 532, 584}; // NEC (non-strict) 121821B0
uint64_t data = 0x121821B0;
30° VENTOLA A 1
Code : 12482170 (32 bits)
uint16_t rawData[67] = {9092, 4430, 600, 504, 598, 508, 576, 504, 600, 1612, 576, 530, 638, 442, 598, 1614, 576, 504, 600, 506, 576, 1610, 600, 506, 576, 530, 574, 1612, 598, 510, 574, 504, 600, 506, 598, 508, 574, 504, 600, 1614, 576, 504, 600, 508, 596, 508, 574, 506, 600, 1612, 576, 530, 574, 1614, 596, 1590, 610, 1604, 574, 504, 610, 496, 608, 498, 574, 532, 584}; // NEC (non-strict) 12482170
uint64_t data = 0x12482170;
30° VENTOLA A 2
Code : 12282170 (32 bits)
uint16_t rawData[67] = {9100, 4422, 608, 524, 580, 526, 548, 532, 582, 1602, 574, 560, 556, 524, 580, 1604, 584, 524, 582, 524, 580, 526, 546, 1612, 608, 526, 548, 1612, 608, 526, 548, 558, 556, 522, 582, 524, 548, 558, 556, 1602, 606, 526, 546, 532, 582, 524, 580, 526, 548, 1612, 608, 526, 546, 1612, 608, 1604, 574, 1612, 598, 536, 546, 532, 584, 522, 580, 526, 548}; // NEC (non-strict) 12282170
uint64_t data = 0x12282170;
30° VENTOLA A 3
Code : 12182170 (32 bits)
uint16_t rawData[67] = {9094, 4452, 576, 504, 602, 504, 578, 528, 576, 1610, 600, 506, 576, 504, 602, 1610, 578, 502, 602, 504, 600, 506, 578, 502, 602, 1610, 578, 1608, 602, 504, 600, 506, 578, 502, 602, 504, 600, 506, 578, 1608, 602, 504, 578, 502, 602, 504, 602, 506, 578, 1608, 602, 504, 578, 1608, 602, 1610, 578, 1608, 602, 504, 580, 500, 604, 502, 602, 504, 632}; // NEC (non-strict) 12182170
uint64_t data = 0x12182170;
31° VENTOLA A 1
Code : 124821F0 (32 bits)
uint16_t rawData[67] = {9096, 4428, 602, 502, 602, 504, 578, 502, 604, 1608, 580, 526, 578, 502, 602, 1612, 578, 502, 602, 504, 580, 1608, 602, 504, 600, 506, 576, 1610, 600, 506, 578, 504, 600, 504, 600, 506, 578, 502, 600, 1612, 578, 502, 602, 504, 600, 506, 576, 504, 602, 1612, 576, 1610, 600, 1612, 576, 1612, 598, 1614, 574, 506, 598, 508, 576, 530, 574, 506, 598}; // NEC (non-strict) 124821F0
uint64_t data = 0x124821F0;
31° VENTOLA A 2
Code : 122821F0 (32 bits)
uint16_t rawData[67] = {9094, 4426, 626, 508, 596, 508, 574, 532, 550, 1634, 554, 526, 578, 528, 576, 1610, 600, 506, 598, 482, 602, 506, 578, 1634, 554, 552, 552, 1608, 600, 506, 576, 556, 582, 472, 600, 506, 578, 556, 548, 1612, 576, 530, 574, 530, 574, 506, 576, 530, 606, 1606, 572, 1614, 574, 1614, 606, 1580, 598, 1614, 606, 474, 630, 476, 596, 510, 574, 506, 598}; // NEC (non-strict) 122821F0
uint64_t data = 0x122821F0;
31° VENTOLA A 3
Code : 121821F0 (32 bits)
uint16_t rawData[67] = {9092, 4430, 580, 526, 578, 528, 576, 530, 574, 1584, 606, 528, 576, 530, 552, 1606, 604, 530, 554, 526, 580, 526, 578, 528, 554, 1604, 604, 1608, 582, 526, 578, 528, 576, 530, 554, 550, 554, 526, 578, 1608, 580, 526, 578, 528, 556, 550, 554, 526, 578, 1606, 582, 1604, 604, 1608, 580, 1606, 582, 1602, 606, 526, 546, 532, 582, 524, 580, 526, 546}; // NEC (non-strict) 121821F0
uint64_t data = 0x121821F0;
32° VENTOLA A 1
Code : 12482108 (32 bits)
uint16_t rawData[67] = {9088, 4434, 596, 510, 574, 506, 610, 498, 596, 1616, 582, 498, 608, 498, 574, 1612, 606, 500, 574, 532, 572, 1612, 574, 532, 574, 506, 608, 1606, 572, 506, 608, 498, 606, 500, 572, 506, 608, 498, 606, 1606, 582, 498, 606, 500, 574, 506, 608, 498, 606, 1606, 572, 508, 606, 500, 594, 512, 572, 508, 608, 1606, 572, 508, 660, 446, 606, 500, 574}; // NEC (non-strict) 12482108
uint64_t data = 0x12482108;
32° VENTOLA A 2
Code : 12282108 (32 bits)
uint16_t rawData[67] = {9094, 4428, 602, 534, 570, 508, 574, 558, 546, 1612, 578, 530, 574, 534, 582, 1602, 576, 532, 582, 524, 550, 530, 574, 1612, 578, 530, 574, 1612, 598, 508, 574, 560, 554, 498, 606, 498, 574, 534, 582, 1604, 574, 532, 572, 534, 580, 500, 574, 532, 572, 1612, 576, 532, 572, 534, 582, 524, 548, 532, 572, 1612, 608, 500, 574, 560, 556, 498, 606}; // NEC (non-strict) 12282108
uint64_t data = 0x12282108;
32° VENTOLA A 3
Code : 12182108 (32 bits)
uint16_t rawData[67] = {9098, 4422, 608, 498, 606, 500, 636, 418, 688, 1550, 574, 532, 572, 506, 610, 1604, 574, 506, 610, 496, 598, 510, 574, 506, 610, 1602, 576, 1610, 598, 510, 574, 532, 572, 506, 608, 498, 574, 532, 574, 1612, 596, 510, 574, 506, 610, 498, 596, 510, 574, 1612, 598, 508, 574, 504, 610, 496, 608, 498, 638, 1550, 608, 498, 574, 530, 574, 506, 608}; // NEC (non-strict) 12182108
uint64_t data = 0x12182108;
FUZNIONE VENTILATORE
VENTOLA A 1
Code : 12412108 (32 bits)
uint16_t rawData[67] = {9096, 4426, 604, 500, 604, 502, 582, 524, 578, 1608, 602, 504, 580, 500, 604, 1608, 580, 500, 604, 502, 602, 1610, 578, 500, 604, 502, 580, 500, 604, 502, 604, 502, 580, 1606, 604, 502, 602, 504, 578, 1608, 602, 502, 580, 526, 578, 502, 604, 502, 580, 1606, 602, 504, 580, 526, 578, 500, 604, 502, 602, 1584, 604, 502, 604, 502, 580, 500, 604}; // NEC (non-strict) 12412108
uint32_t address = 0x8248;
uint64_t data = 0x12412108;
VENTOLA A 2
Code : 12212108 (32 bits)
uint16_t rawData[67] = {9092, 4426, 656, 448, 604, 502, 582, 524, 600, 1586, 602, 504, 578, 500, 604, 1608, 602, 478, 604, 502, 572, 534, 582, 1604, 594, 512, 604, 502, 602, 478, 626, 480, 572, 1614, 628, 478, 574, 532, 656, 1530, 596, 508, 574, 534, 602, 476, 628, 478, 604, 1582, 596, 508, 574, 532, 604, 476, 628, 478, 574, 1612, 630, 476, 596, 510, 606, 500, 634}; // NEC (non-strict) 12212108
uint32_t address = 0x8448;
uint64_t data = 0x12212108;
VENTOLA A 3
Code : 12112108 (32 bits)
uint16_t rawData[67] = {9092, 4454, 608, 472, 632, 474, 652, 454, 608, 1578, 630, 476, 576, 528, 606, 1580, 576, 528, 608, 472, 632, 474, 598, 508, 606, 1580, 630, 476, 628, 452, 632, 474, 598, 1614, 606, 474, 630, 474, 576, 1610, 632, 474, 598, 508, 606, 474, 632, 474, 630, 1556, 632, 474, 630, 476, 576, 530, 606, 474, 630, 1582, 606, 472, 652, 454, 578, 528, 638}; // NEC (non-strict) 12112108
uint32_t address = 0x8848;
uint64_t data = 0x12112108;
FUNZIONE DEUMIDIFICATORE
VENTOLA A 1
Code : 12422108 (32 bits)
uint16_t rawData[67] = {9090, 4454, 576, 504, 600, 506, 630, 476, 576, 1610, 600, 506, 576, 528, 576, 1610, 630, 476, 576, 504, 600, 1612, 576, 502, 602, 504, 632, 474, 578, 528, 576, 1610, 632, 448, 602, 502, 602, 504, 632, 1554, 602, 504, 632, 472, 580, 500, 604, 502, 634, 1578, 578, 502, 604, 502, 622, 484, 578, 500, 604, 1610, 578, 500, 604, 502, 634, 472, 580}; // NEC (non-strict) 12422108
uint32_t address = 0x4248;
uint64_t data = 0x12422108;
VENTOLA A 2
Code : 12222108 (32 bits)
uint16_t rawData[67] = {9090, 4456, 574, 504, 600, 506, 598, 508, 574, 1612, 598, 508, 576, 504, 600, 1612, 576, 530, 576, 504, 600, 506, 576, 1608, 600, 506, 600, 506, 576, 504, 600, 1612, 576, 504, 600, 504, 600, 506, 576, 1608, 600, 506, 578, 502, 602, 504, 600, 504, 578, 1608, 602, 504, 600, 506, 576, 502, 602, 504, 600, 1614, 576, 504, 600, 506, 578, 528, 576}; // NEC (non-strict) 12222108
uint32_t address = 0x4448;
uint64_t data = 0x12222108;
VENTOLA A 3
Code : 12122108 (32 bits)
uint16_t rawData[67] = {9092, 4430, 600, 504, 578, 502, 602, 504, 602, 1610, 578, 502, 602, 504, 578, 1608, 602, 504, 600, 506, 578, 502, 602, 504, 600, 1586, 602, 506, 600, 506, 630, 1556, 600, 506, 578, 528, 576, 502, 602, 1612, 576, 502, 602, 504, 600, 506, 576, 504, 602, 1610, 578, 502, 602, 504, 600, 506, 576, 504, 600, 1612, 578, 528, 576, 504, 600, 506, 576}; // NEC (non-strict) 12122108
uint32_t address = 0x4848;
uint64_t data = 0x12122108;
ALTRE FUNZIONI
IMPOSTAZIONE GRADI FAHRENHEIT
Code : 1218259A (32 bits)
uint16_t rawData[67] = {9092, 4430, 600, 506, 600, 508, 574, 506, 598, 1614, 576, 530, 574, 506, 610, 1604, 574, 506, 608, 498, 596, 510, 574, 506, 608, 1604, 574, 1612, 596, 510, 574, 506, 600, 506, 598, 508, 574, 532, 574, 1614, 596, 510, 572, 506, 608, 1604, 574, 506, 608, 1604, 574, 1612, 598, 508, 574, 506, 608, 1604, 574, 1612, 608, 498, 576, 1610, 608, 498, 576}; // NEC (non-strict) 1218259A
uint64_t data = 0x1218259A;
IMPOSTAZIONE GRADI CELSIUS
uint16_t rawData[67] = {9096, 4450, 580, 500, 604, 502, 602, 476, 606, 1606, 602, 504, 580, 500, 658, 1556, 580, 498, 606, 500, 604, 502, 580, 524, 580, 1608, 570, 1614, 606, 500, 604, 502, 582, 498, 606, 500, 604, 502, 580, 1606, 604, 502, 580, 526, 578, 502, 602, 504, 580, 1606, 604, 502, 602, 504, 580, 500, 604, 502, 602, 1584, 604, 502, 602, 504, 580, 500, 606}; // NEC (non-strict) 12182108
Ultima modifica di fumiplettro il 10/07/2019, 15:15, modificato 3 volte in totale.
 #707  da gpl71
 09/07/2019, 14:47
fumiplettro ha scritto: 08/07/2019, 17:37 Per inserirli in un firmware come procedere?
E' un po complessa questa parte.
Devi installare l'ambiente per poter sviluppare firmware Homekit oppure attendere Francesco Curletti che pian piano integri i codici nel suo firmware e li carichi nella repo di GitHub
 #718  da fumiplettro
 10/07/2019, 15:12
Ho modificato un errore di battitura su 22° ventola a 3. doveva essere 21° ventola a 3. Il codice ora è corretto. Inoltre mi permetto di aggiungere il link dei codici HEX ricavati tramite Broadlink RM Mini 3. Spero possano servire
