Buonasera a tutti ho bisogno di un aiuto con Homebrige che sembra aver smesso di funzionare..
L'ultima operazione che ho fatto è aggiornare il Plugin di Shelly.
Questo è quello che succede..![Confused :?](./images/smilies/icon_e_confused.gif)
Codice: Seleziona tutto
Ho controllato il file config.json con il validatore e sembra essere ok.. pi@raspberrypi:~ $ sudo systemctl status homebridge
● homebridge.service - Node.js HomeKit Server
Loaded: loaded (/etc/systemd/system/homebridge.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2019-09-25 21:57:33 CEST; 19s ago
Main PID: 27649 (homebridge)
CGroup: /system.slice/homebridge.service
└─27649 homebridge
set 25 21:57:50 raspberrypi homebridge[27649]: [2019-9-25 21:57:50] Loaded plugin: homebridge-dummy
set 25 21:57:50 raspberrypi homebridge[27649]: [2019-9-25 21:57:50] Registering accessory 'homebridge-dummy.DummySwitch'
set 25 21:57:50 raspberrypi homebridge[27649]: [2019-9-25 21:57:50] ---
set 25 21:57:50 raspberrypi homebridge[27649]: [2019-9-25 21:57:50] Loaded plugin: homebridge-raspberrypi-remote
set 25 21:57:50 raspberrypi homebridge[27649]: [2019-9-25 21:57:50] Registering accessory 'homebridge-raspberrypi-remote.RaspberryPi'
set 25 21:57:50 raspberrypi homebridge[27649]: [2019-9-25 21:57:50] Loaded plugin: homebridge-shelly
set 25 21:57:51 raspberrypi homebridge[27649]: [2019-9-25 21:57:51] Registering platform 'homebridge-shelly.Shelly'
set 25 21:57:51 raspberrypi homebridge[27649]: [2019-9-25 21:57:51] ---
set 25 21:57:53 raspberrypi homebridge[27649]: [2019-9-25 21:57:53] Loaded plugin: homebridge-weather-plus
